FCPwr - How does it work?
Posted: Wed Dec 10, 2025 12:46 am
by zimluc
Hi all:
The force charging mode presents me with an option to customize the FCPwr variable.
However, whichever power rate I choose gets to be completely ignored.
As for the FCSoc, I've tried to set to 20% and also to 100%. No difference.
I even configured a limit of 27A for the battery charging rate within the inverter's config parameters.
Nonetheless, force charging mode simply sends to the battery the highest possible power (10,500W minus the loads).
I wish it could work just like the force discharging mode in which it reads the FDPwr variable accordingly.
Could someone please shed some light?
Tks in advance.
Mine is a KH10.5 inverter along with a 10kWh battery.
Master 1.39
Slave 1.01
Manager 1.35
Re: FCPwr - How does it work?
Posted: Wed Dec 10, 2025 8:06 am
It’s your firmware that is too old, the FCxxx functions only work on the latest firmware where FCPwr will set charging power and FCSoC must be set the same as your maxSoC value.
