Does the fact the Inverter display has the wrong time effect the Mode Scheduler?
Posted: Sat Dec 06, 2025 9:25 am
by TimB100
Hello all
Just had my Solar, Battery and Inverter installed
Inverter is a 5kw H1-5.0-E-G2-WL
Battery is EP12
I have been trying to set up the Mode Scheduler in anticipation of a new Tariff, but it was not following the schedules I set, started charging outside my set range etc.
I then noticed that the display time on the Inverter is the wrong date and time.
Would be the reason for the wrong charge/discharge times and if so how do I fix it?
Many thank
TimB
Re: Does the fact the Inverter display has the wrong time effect the Mode Scheduler?
Posted: Sat Dec 06, 2025 9:33 am
by Will
Yes, the inverter date/time being correct is critical you can manually correct.
If it continues to drift, make sure all your firmware is up to date as older versions had an issue with the inverters time not correctly syncing with the cloud.
Posted: Sat Dec 06, 2025 9:36 am
Yes if the time is wrong on the display the inverter won't follow schedules properly - everything the inverter does is local to it's time clock.
It's unusual for it not to be set by the Fox cloud every day - how new is your installation ?
I've seen on older installs that the datalogger appears to stop acting on the time clock updates from Fox, in that case remove the datalogger wait 10 seconds and plug it back in and that should cure it.
The time clock only updates in the early hours so you will need to set it your self for now (In Setting, Date & Time), and then keep a close eye on it as it will slowly drift by a second or two each day if it doesn't receive those time syncs from the datalogger.
Posted: Sat Dec 06, 2025 9:37 am
Lol, sorry Will - we posted together :)
Posted: Sat Dec 06, 2025 9:43 am
by Will
team effort Dave, no worries.
Posted: Sat Dec 06, 2025 5:07 pm
by TimB100
Thanks for the replies
To answer some of the questions and to raise one
The system was installed on the 4 Dec 2025
The FIrmware is the following
Master 1.40
Slave 1.04
Manager 1.26
I would have expected it would have pulled the time date of a web time/date server but it has not.
How do I correct the data/time? I tried on the front panel but I got as far as it asking for a password
I can find no settings on the APP or the cloud interface.
I presume I need to contact FOX to get them to remotely update any firmware
Thanks again
TimB
Posted: Sat Dec 06, 2025 5:20 pm
by Will
Your installer can correct the date/time and remotely install the latest firmware for you.
If you want to update the date and time on your inverter, it's under settings > 0000 > date/time
I would also make sure the timezone is correct in your site's settings.
Posted: Sat Dec 06, 2025 6:38 pm
by TimB100
There is no settings option in the app or the cloud interface as far as I can see.
TimB
Posted: Sat Dec 06, 2025 6:47 pm
by TimB100
Ok figured it out. Front panel 0,0,0,0 password and was in. Date corrected
TimB
Posted: Sat Aug 22, 2026 12:46 pm
by spellingerror
Hi, just picking up this thread because it's similar to my problem. My inverter will change its time to be five hours slow some time during the night. I'l reset it in the morning, and it'll be fine for the day, but by the next morning it will be five hours out again. Always five hours. Any idea what the issue is and how to solve it?
Inverter model H1-3.7-E-G2-WL
Master 1.57
Slave 1.04
Manager 1.43
Software 2.09
Posted: Sat Aug 22, 2026 1:32 pm
spellingerror wrote: Sat Aug 22, 2026 12:46 pm Hi, just picking up this thread because it's similar to my problem. My inverter will change its time to be five hours slow some time during the night. I'l reset it in the morning, and it'll be fine for the day, but by the next morning it will be five hours out again. Always five hours. Any idea what the issue is and how to solve it?
Master 1.57
Slave 1.04
Manager 1.43
Software 2.09
Yes the scheduler will be 5 hours out as well as it runs in local (inverter) time - it sounds like you haven't set your locale. In the app, click the 3 dots in the top right corner, Edit Home, and make sure your location and time zone are set correctly. The Fox cloud should then reset your inverter clock to the correct time overnight.
Posted: Sat Aug 22, 2026 2:04 pm
by spellingerror
Dave Foster wrote: Sat Aug 22, 2026 1:32 pm
Master 1.57
Slave 1.04
Manager 1.43
Software 2.09
Aha, time zone was set to America/Anguilla. Hopefully that'll sort it. The installers were supremely unhelpful with this so thank you!
Posted: Tue Sep 01, 2026 8:07 am
by spellingerror
I'm back. Although the time zone was changed in the app, the time on the inverter is still resetting to -5 hours every night. I've tried looking at every setting in the app and have also gone to Me > User > Country/Region and changed it to UK (it was empty before) but not sure if that will help at all. Not sure if there's any others that I should change?
Posted: Tue Sep 01, 2026 9:33 am
by MaterialBarracuda48
spellingerror wrote: Tue Sep 01, 2026 8:07 am I'm back. Although the time zone was changed in the app, the time on the inverter is still resetting to -5 hours every night. I've tried looking at every setting in the app and have also gone to Me > User > Country/Region and changed it to UK (it was empty before) but not sure if that will help at all. Not sure if there's any others that I should change?
As you have made a change, wait for tomorrow to see. (Maybe a reboot of the Inverter before tomorrow?)
If this cures it, then you are good to go, if not contact installer/Fox for further support.
Posted: Tue Sep 01, 2026 9:43 am
by spellingerror
Thanks, I will. How does one reboot the inverter? And is there a best time of day to do it?
Posted: Tue Sep 01, 2026 12:12 pm
spellingerror wrote: Tue Sep 01, 2026 9:43 am Thanks, I will. How does one reboot the inverter? And is there a best time of day to do it?
Highly recommend that you add Will's channel to your favourites https://www.youtube.com/@iameccles/videos
One times guide :)
Posted: Tue Sep 01, 2026 12:30 pm
by spellingerror
MaterialBarracuda48 wrote: Tue Sep 01, 2026 12:12 pm
One times guide :)
Cheers
