Cheap Rate Charging Maths
Posted: Mon Dec 01, 2025 2:33 pm
Noobie here so apologies if this has already been covered ...
I'm trying to work out wether or not to exit my fixed rate deal and change to overnight charging at a cheaper rate and battery usage during the day?
First off; I'm not exactly sure if I can (or how to) set the system up to charge the battery overnight and then use solar or battery during the day?
I have a FOX EPS 5.18kwh battery with 4.6 kWh usable capacity.
Secondly; I'm assuming that my savings would be the difference between the fixed rate (26.65p) and the cheap overnight rate (6.5p) i.e. 4.6 x (26.65 - 6.5) = 92.69p / day ?
Cheers in advance.
Chris
Cheers in advance.
Chris
