Battery System constantly pulling a small amount from the grid
Posted: Mon Dec 01, 2025 11:05 am
I've just had a new battery system installed onto an existing solar panel installation. Before the battery install, my base load was 0W most of the time.
Since the battery install, the baseload is, on average, 23W and I can see from my smart meter IHD that the system is constantly pulling a small amount from the grid, even when the batteries have power and the sun is shining.
I would expect nothing to be pulled from the grid if battery/solar power is available. I understand that sometimes power will come from the grid when the battery is lagging if something like the oven is turned on, but that this would go back to zero once the batteries were supplying the power.
Is this normal behaviour? It adds up to about 0.5kwh per day which, although small, is more than I would expect.
