CODE-3 Ground Fault on Inverter after EV charging installed?
Posted: Fri Nov 28, 2025 10:29 am
Hello, am super happy to find this community of experts! Hope I can request some help.
We have 10 PV panels connected to an EP11 battery via an H1-G2 inverter installed in April and have been really happy with the system. We had a Ohme Home Pro EV charging point installed on Monday and ever since the app and inverter from panel have been reporting a CODE-3 Ground Fault that hasn't cleared down by a power off reset of the inverter/battery.
None of the RCD trips appear to be flipped and all the home electrics including the charging point appear to be working as expected, except the PV no longer charges the battery, so I've set a forced time charge to add some overnight energy (we're on Octopus Intelligent Go)
I am hoping the electrician is able to get back to check the connections sometime today, would be useful to know if there are any "gotchas" to look for - added some pictures of what the install looks like if that helps.
