Axle VPP new Grid Services mode, compatible with Home Assistant & Predbat
Posted: Fri Nov 21, 2025 4:48 pm
by archyaxleenergy
We launched the Axle Energy Virtual Power Plant a few weeks ago, which includes optimisation against your bill + earnings from supporting the grid.
We’ve had lots of great feedback, made a ton of updates, and already paid out hundreds of £ of earnings to users whose batteries have exported to help the grid at key times.
After lots of requests, we’ve now added the ability to sign up for grid services only, keeping your existing optimisation setup.
And yes, this means we are now compatible with Home Assistant, or manual scheduling within the Fox app!
This lets you:
  • Keep every day control of your battery, to optimise as you see fit
  • Participate in events when the grid is under strain (paid at £1/kWh for energy we export)
  • Earn revenue from the VPP whilst combining with your favourite optimisation product such as Home Assistant or Predbat.
https://vpp.axle.energy/landing/grid
Please give it a go (or let us know what you’d like to see that isn’t there!) - we still guarantee at least £10 a month and we’re currently offering a £20 signup bonus to new beta users 🙏🏻
Re: Axle VPP new Grid Services mode, compatible with Home Assistant & Predbat
Posted: Mon Dec 22, 2025 1:57 am
by WyndStryke
Just as an update to this, starting from v8.30.0, predbat has added a component to query the Axle REST API and set itself up appropriately.
Posted: Thu May 14, 2026 10:26 am
by jaylo
Axle seem to be adding a Schedule to the Inverter - which is fine, I think (I use the FoxESS Modbus integration with HA/Predbat, so don't usually use the Scheduler functionality).
But then the Schedule remains enabled once the event is finished, which I think will force it to discharge at the same time every day from then on.
Can Axle remove (or at least disable) their schedule after the event?
Posted: Thu May 14, 2026 11:56 am
by WyndStryke
They normally clear it within about 30 minutes of the event ending (and often quicker).
It's not 100%, which is why the email which comes after the event asks users to double-check the schedule and clear it themselves if necessary.
Posted: Mon Jun 29, 2026 12:09 pm
by spmaid
I'm signed up for the Axle VPP events, and that works fine apart from I have noticed that when an export is scheduled from the Mode Scheduler, I can only get about 5kW of export from the Inverter, if I change the mode to be Forced Discharge, I get the full 6kW.
On the attached image, you can see each time the Axle Mode Schedule kicks in, it drops to 5kW, I then quickly override and it bumps back up to 6kW, until Axle refresh the Mode Schedule.
Any thoughts on why a Mode Scheduled export, which is correctly set to 6000W in the schedule isnt managing 6kW but my Forced Discharge is?
Posted: Mon Jun 29, 2026 12:13 pm
by WyndStryke
Have you got (relatively) recent firmware? I had old firmware (around Jan 2025), and there were odd things happening with discharge speed. Did a firmware update about 5 months ago and everything started working perfectly with Axle.
Posted: Mon Jun 29, 2026 12:27 pm
by spmaid
I did check that and I appear to be on the latest Firmware versions for my H1 (Gen 1) and HV2600 batteries.
Version_Master:
1.70
Version_Slave:
1.02
Version_ARM:
1.78
Posted: Mon Jun 29, 2026 3:37 pm
by MaterialBarracuda48
Over the 1hr discharge window, you go from around 5.2kW to almost 6kW at the end.
Maybe the grid Voltage on your local network is affecting the rate?
Posted: Mon Jun 29, 2026 3:51 pm
by WyndStryke
Oh one thought - this is just battery discharge, you also have to take into account any PV.
(Ignoring losses for simplicity)
If your inverter is 6kW, and and you are getting 1kW from the array, then it'll only pull 5kW from the battery because the inverter capacity is saturated. That'd give you 6kW of AC.
Then for export, you need to subtract any household load. So if your household load is 200W, then you'd be exporting 5.8kW.
Try doing the same graph again, but also add in the entities for solar generation, inverter power, household load, and feed-in.
Inverter power = solar generation + battery discharge - losses
Feed-in = inverter power - household load - losses
Another thing to look at is how the mode scheduler is being configured by Axle during the event. What's the exact mode, do they specify a discharge power? So if they have configured the mode scheduler to only convert to AC at 5kW then that's all you'll get. There are also some modes which can be scheduled via API which aren't options for normal users. For example, force discharge (BAT) is different from the normal force discharge.
Posted: Mon Jun 29, 2026 3:55 pm
by spmaid
MaterialBarracuda48 wrote: ↑Mon Jun 29, 2026 3:37 pm Over the 1hr discharge window, you go from around 5.2kW to almost 6kW at the end.
That's due to the falling Solar, sorry. When the Mode Scheduler is exporting, I am only exporting to grid around 5kW, but when I force it by changing to Force Discharge, that jumps up a kW.
Posted: Mon Jun 29, 2026 3:58 pm
by spmaid
WyndStryke wrote: ↑Mon Jun 29, 2026 3:51 pm Oh one thought - this is just battery discharge, you also have to take into account any PV.
Correct, yes, house use during that time is just under 1kW, and to start there was also about 1kW of Solar I think, hence battery discharge starts around 5kW before reaching nearly 6kW at the end of the session, but note the drops when the Axle Mode Schedule kicks in, then briefly drops to zero as I was manually overriding, it then jumps about 1kW higher, until the Axle Mode Schedule is refreshed by them again. They send it several times over the hour session.
Posted: Mon Jun 29, 2026 4:01 pm
by WyndStryke
During the next event, try grabbing a screenshot of the mode scheduler so that you can see the exact way it has been configured. There are a couple of things which might affect it.
Alternatively, you could drop a line to Axle support asking them to look at the mode & discharge rate which was set for your system (it is a beta test, after all).
Posted: Mon Jun 29, 2026 4:17 pm
by spmaid
WyndStryke wrote: ↑Mon Jun 29, 2026 4:01 pm During the next event, try grabbing a screenshot of the mode scheduler so that you can see the exact way it has been configured. There are a couple of things which might affect it.
I think I might have, I'll take a look, it all looked ok, and I was able to replicate it, and get the same result, i.e. only 5kW of export (combined battery discharge and PV)
I have added PV, Grid and house load to the chart, and marked up the graphs, in white where I was forcing the discharge then where the Mode Schedule kicked in (pink) showing the export to grid drops to match (ignoring the house loads which also cause dips of course)
I'll mention it to Axle, but I am guessing this is a Fox issue as I can replicate by doing the same, and I just checked the Schedule, it's still there from last week, as it doesnt deleter or even disable once the session is over, I have to manually do that, also attached that.
Posted: Thu Jul 16, 2026 4:16 pm
Does anyone know if Axle VPP respects the Inverter export limit during events, or does it override?
I have 3.9kW export limit from my G99, and tonight I have my first event. In 'Your devices' it shows dispatch power as 7kW.
I dare say that it respects the G99 limit set.
Posted: Thu Jul 16, 2026 4:28 pm
by WyndStryke
The limit in the 'your devices' is just what your inverter is capable of, and I think it is purely informational on the part of Axle (i.e., they'll ask the inverter to export at it's max rate, and the inverter will restrict it to 3.9kW in your case, provided that the G100 settings have been configured correctly by your installer/yourself). I presume you have a KH7.
Axle use the limit in the 'your devices' list to estimate how much can be exported, so they'll see it as a shortfall from your system. I'm not sure if they'll go back and change it after you've done a few events and they can see the actual export.
It looks like a user-editable setting, so you could adjust it yourself.
I think in some cases, Axle control the main inverter, and there are parallel inverters which they can't see, so for some people it'll be higher rather than the same or lower.
I don't know what happens if you were to set it to 2kW (for example), whether it'd limit the output or whether it'd still go all-out but then underestimate the export.
Posted: Thu Jul 16, 2026 4:42 pm
Thank you for the reply Wyndstryke, I thought you would answer.
Yeah running KH7, I am on G99 (3.9kW, not G100 3.68kW)
I did see that I could ramp it down on the settings, but I am leaving it on 7kW and find out what it does for certain.
I suspect it will respect the hard limit, but never know!
You must have done a fair few sessions now with Axle, I guess doing OK with it all (apart from maybe earlier small issues I have seen reported from people)
Posted: Thu Jul 16, 2026 4:49 pm
by WyndStryke
Lifetime Earnings
£139.80
Events Joined
17
I think I've done every event available for my location - for both December events I was flying, it was a struggle trying to get some internet in a Chinese airport to see what my system was doing. It needed a lot of hand-holding initially, sometimes having to manually force discharge, sometimes having to stop it importing instead of exporting, that sort of thing, but it's been running perfectly for most of this year. The "importing instead of exporting" was fixed by a firmware update, but I know that you have more recent firmware than that, so it should be fine.
I did write a HA automation to take over the system and do the force-export if the Axle schedule failed to work, but it hasn't needed to intervene for a long time. It also makes a note of the feed-in-today figures immediately before and after the event, and similar housekeeping, and I have another automation that cuts the power to unnecessary household loads during the event. Although one morning event happened to be at the same time that Alexa's morning alarm goes off, and Alexa was one of the 'unnecessary household loads' so I ended up oversleeping ...
Posted: Thu Jul 16, 2026 5:09 pm
Good to see you made some good moolah, I joined up just after a lot of power down sessions (Octopus) so missed a window.
Rough with regards to the missed alarm, won't be doing that in a hurry!
Posted: Thu Jul 16, 2026 8:03 pm
MaterialBarracuda48 wrote: ↑Thu Jul 16, 2026 4:16 pm Does anyone know if Axle VPP respects the Inverter export limit during events, or does it override?
An update if anyone asks this question in the future.
It set a discharge schedule up, for 7kW... but it DOES respect the G99 system set export limit of 3.9kW.
