Daily SOC drop on EP5 battery — is this expected behavior?
Posted: Thu Nov 20, 2025 8:55 am
I have a FoxESS hybrid system with an EP5 battery and a KH7.5 inverter configured in backup mode. Every day, at almost the same time early in the morning, the battery discharges by about 5% (from 97% down to ~92%), even though:
There is no load connected to the backup output,
The system shows no faults,
The inverter remains in normal operation,
Grid power is stable.
After that drop, the battery stays at ~92% until solar production starts.
My question is:
Is this daily scheduled discharge normal behavior for the EP5/BMS or for FoxESS hybrid inverters?
If so, what internal process causes this (e.g., cell balancing, BMS calibration, internal maintenance cycle)?
And is ~8% a typical amount?
I have attached some images to illustrate this behavior.
I would appreciate any clarification or documentation explaining this behavior.
Thank you!
My question is:
Thank you!
