Modbus server via the included wifi module for the new H1-Gen2-WL and H3 Smart models
Posted: Wed Nov 19, 2025 9:11 pm
by skwaler
I saw this video showing that it is now a modbus server on the newer inverters.
https://www.youtube.com/watch?v=q8A32xMifmA
I tried using my H3 Smart 15kW but get this error:
changed to Error reading registers. Type: RegisterType.HOLDING; start: 31000; count: 91; slave: 247 from tcp://IP_ADDRESS:502: Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 8 bytes (0 received)
Master : 1.30 Slave : 1.00 Manager : 1.18
Has anyone had any luck? Firmware version or some thing needs to be enabled?
Re: Modbus server via the included wifi module for the new H1-Gen2-WL and H3 Smart models
Posted: Wed Nov 19, 2025 9:34 pm
by Will
That’s my video. Does your inverter have an integrated data logger or a plug in module?
Posted: Wed Nov 19, 2025 9:36 pm
by skwaler
It's got the integrated datalogger (Type: WL-H3-G2).
Posted: Wed Dec 10, 2025 3:32 am
by Trentan
I have similar (integrated datalogger (Type: WL-H3-G2) + Device: H3-9.9-Smart)
I can't find the ip on my lan / anyway to customise it.
I can connect to the wifi of the device (using the wifi W* and password mtmt2020 - but there is no configuration page?
"In the address bar, type 192.168.1.1.
This will open the dongle's configuration interface"
Stuck as would be cool to integrate this into Home assistant
Posted: Wed Dec 10, 2025 5:59 am
by Trentan
Yeah getting same error - I redid the wifi network and snagged the ip:
Error connecting to inverter (friendly name: "FoxEss"). Error reading registers. Type: RegisterType.HOLDING; start: 31000; count: 91; slave: 247 from tcp://192.168.68.106:502: Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 8 bytes (0 received)
Posted: Tue Dec 23, 2025 12:30 pm
by Trentan
I might have to raise something with the home assistant project, as using my phone and an app, it can read the registers! Just home assistant app can't.
Getting close
https://imgur.com/a/bqPdLNc
Posted: Tue Dec 23, 2025 1:25 pm
by Trentan
Got it working, seems a few others had similar issues!
https://github.com/nathanmarlor/foxess_ ... ssions/994
"Answered by williamjeccles
2 days ago
You don’t need a modbus device. Just use the inverters ip address and set the integration to direct lan using the latest beta version and it will work. Smart and WL inverters have a tcp modbus server built into them."
Use the beta version of the release and make sure your inverter updated to the latest version.
Awesome to get the modbus info directly in home assistant now.
Posted: Sun Dec 28, 2025 5:27 am
by glasswire
Trentan wrote: Tue Dec 23, 2025 1:25 pm Got it working, seems a few others had similar issues!
2 days ago
I am getting the "Modbus Error: [Input/Output] Modbus Error: [Invalid Message] No response received, expected at least 8 bytes (0 received)" error.
What version of firmware fixed the issue for the H3 Smart?
Posted: Sun Dec 28, 2025 10:27 am
by Trentan
You have to select the most recent beta release / version (not the standard one).
Think a few others had similar issues and a beta release fixed it.
Posted: Sun Mar 29, 2026 11:40 am
by tonyhughes
trying this with the H3 smart pro get Error connecting to your inverter. Details: Inverter model not supported: ''
Posted: Sun Mar 29, 2026 11:49 am
by Trentan
Yeah it is finnicky and I have not chased up a request to fix / debug it with the devs - its working for me I am just choosing not to upgrade my stuff until it works / someone comments here.
I used these versions to get it working, try downgrade use these:
FoxEss modbus - v1.14.0b3
Home Assistant Core - 2026.1.2
Let me know if that fixes it for you.
If someone else can raise the problem with the devs (not sure if HA or fox modbus breaking with upgrade) and report back here would be appreciated:
Posted: Sun Mar 29, 2026 12:14 pm
by tonyhughes
mate i've tried with all versions v1.15.0b1 , v1.14.0b3 and b2 and b1 no luck....Only got the system 3 days ago...
will hit them up see if they can take a look.
Posted: Sun Mar 29, 2026 7:51 pm
by glasswire
tonyhughes wrote: Sun Mar 29, 2026 12:14 pm mate i've tried with all versions v1.15.0b1 , v1.14.0b3 and b2 and b1 no luck....Only got the system 3 days ago...
You just need the latest beta of the foxess Modbus HA integration and it will work
