Full discharge full cycle method
Posted: Sat Apr 15, 2023 7:54 pm
by Daviessteve
Just installed an additional 2 Mira 2k5 on a Fox hybrid inverter which had 2 Mira 2k5 batteries when originally installed
Not convinced that the additional batteries are being seen by the system properly
Battery voltage is >200v so system knows the batteries have been added and connected correctly
I am seeing people referring to a Full - discharge - full cycle but I cannot find out how to do this
Any help would be great
Best regards
Steve
Re: Full discharge full cycle method
Posted: Sun Apr 16, 2023 2:22 pm
by Daviessteve
I carried out a full forced charge, followed by a full discharge, followed by a full forced charge by isolating the Panels
I then turned the system off and restarted
Can anyone please confirm that the RUN leds on all battery modules flash at the same time
I am sure that before I did this process the RUN leds flashed in sequence
Steve
Posted: Sun Apr 16, 2023 7:11 pm
by asyrop
Hi Steve,
I have done something similar to you, though only adding one battery - otherwise I have limited knowledge. I can confirm that the run LED on my batteries were not exactly together nor in sequence. They each seemed to be on for about 1sec and then off for about 1sec, to the same periodic beat but they are neither together nor sequential, so the timing between them is consistent but would appear to be otherwise random.
So I decided to check it out further and turned off the BMS for a few secs and then on again. The BMS rebooted and soon had a steady run light - at this point all 3 battery run lights were flashing together in sync. They have stayed this way for a while - so I conclude that they start off in sync but over a period of time their individual internal clocks get out of sync. Would this explain your observation ?
I hope this may help. I chose not to carry out the immediate charge/discharge cycles as you have tried, though I saw the advice. I agree I would prefer more precise instructions as to what is important in such a cycle. However, I have been monitoring the performance of the adjusted battery set by checking the energy delivered overnight when there is no solar PV - I can see a 50% increase in total capacity with 3 in place of 2 batteries, so remain content.
Regards
Alan
Posted: Mon Apr 17, 2023 8:36 pm
by Daviessteve
Just received this reply from Fox support
‘’Hi Steve,
Your system is recognising all 4 batteries.
However it seems the new batteries were added with a different voltage to the original set.
They are in the process of balancing so you may notice a reduction in capacity until they balance.
This process can take between 1 week and 2 months depending on how different the voltage of the batteries was when they were added.
But for now, everything seems normal for your case.
If there are any additional questions please reply to this email.
Kind regards,
FoxESS UK Service’’
I do think there needs to be a clearer instruction regarding adding more battery capacity
Not exactly plug and play
Posted: Wed Apr 19, 2023 5:42 pm
by Daviessteve
Fair play Fox UK support are good
They have just confirmed that my batteries are balanced
They can remotely interrogate my system
They did say they have a capability to assist the balancing process
I have already seen a much increased capacity
Well done to Fox Support UK
Well worth contacting this team if you need help or advice
