Parallel force charge
Posted: Sun Nov 16, 2025 3:25 pm
by ohkayell
Hi, am a bit confused as to how the parallel mode should work for a force charge or discharge wondering if anyone can help. I have 2x 3.7kw H1-g2 set up in parallel mode and seems to work ok in self use mode and the load is split 50/50 but unsure how the work-mode setting is meant to be used?, Should the slave follow whatever the master is doing or do i need to set both?. I cannot seem to get my slave device to force charge at all, when i set master too force charge the slave carries on exporting rather than import?, any ideas?
