FoxESS to Home Assistant Integration Options (T Series)
As FoxESS has grown its market share globally, it's been under active development from its community of developers who want to extend its functionality, reporting and automation capabilities.
It's now possible to integrate your T series FoxESS solar inverter with Home Assistant.
1. FoxESS Local RS485 Modbus Integration https://github.com/assembly12/Foxess-T- ... Assistant
Pros:
  • Realtime data polling via the RS485 port
  • Comprehensive list of data entities to report on and build dashboards using
Cons:
  • additional hardware or cabling needed
Re: FoxESS to Home Assistant Integration Options (T Series)
nice job! I have intel nuc next to my FoxEss and I already have RS485 to TTL (usb module) do you think it is possible reproducing your code inside node red? as this is not using pooling but waiting for stream right?
