Disconnect Octopus API
Posted: Fri Oct 31, 2025 7:46 am
by andreterblanche
Hi, does anyone know how to disconnect Octopus API. I have tried to delete my Octopus account number and API key on the FoxESS web portal, but keeps getting an Invalid Parameter error message. Thanks.
Re: Disconnect Octopus API
Posted: Fri Oct 31, 2025 9:29 am
by MaterialBarracuda48
It is the same for me, I cannot delete it.
On an interesting note, the wording of the mode "Octopus Agile" is now not accurate, as it pulls down the pricing for your account.
I am with Octopus Go, and you can see the pricing for your region.
If you have your scheduler set to manual, or you have disabled all the schedulers, then it shouldn't matter.
The other option is to regenerate your Octopus API key, so it should make the saved one invalid, you will of course have to input the new key into any other systems you are using your Octopus key with.
Posted: Fri Oct 31, 2025 9:34 am
by andreterblanche
Thank you! I have signed up with Axle energy for beta remote battery management. I just wanted to make sure the Octopus integration wasn't going to interfere.
Posted: Fri Oct 31, 2025 9:40 am
andreterblanche wrote: ↑Fri Oct 31, 2025 9:34 am Thank you! I have signed up with Axle energy for beta remote battery management. I just wanted to make sure the Octopus integration wasn't going to interfere.
Don't quote me for certain, but I think that the way they take over your system overrides your schedules anyway, either way I would perhaps leave the Octopus API Key alone, and just turn off all the schedulers which you should be able to do via the app.
If I can dig out a FAQ then maybe I can find out where I read it from.
Posted: Fri Oct 31, 2025 3:31 pm
by andreterblanche
Thanks. I will try the suggested settings. Fingers crossed...
