H3 Pro vs EPS Box Pro
Posted: Sat Oct 25, 2025 8:50 am
Hi all,
It seems the H3 Pro 30kW has an EPS output for keeping the loads powered in the event of a mains outage.
Why is would an EPS Box Pro be needed?
Is it correct to assume that when in "offgrid" mode, the EPS Box Pro would only be able to provide 25A per phase ?
And is it correct to assume that when in "offgrid" mode, the H3 Pro 30kW would be able to provide 45.5A per phase ?
Finally the H3 Pro does the switch in under 10ms from grid into backup power ?
And the EPS Box Pro would take about 3 seconds ?
So in all cases there is no actual advantage between the EPS box pro compared to the H3 pro ?
