Newest firmware for H3-10.0-E, EP11 and W6
Posted: Tue Oct 21, 2025 8:05 pm
by chris79
I have asked my installer to trigger an update of all my components as based on Will's table my versions were outdated.
Suprisingly, after the updates I have partly even newer versions installed now:
H3-10.0-E
Version_Master: from 2.03 to 2.19
Version_Slave: remained on 1.03
Version_ARM: from 1.81 to 1.91
DataLogger W6: from 1.04 to 1.08
Battery EP11: from 1.004 to 1.008
Maybe helpful for others - so far things seems to run fine.
Best regards
Christoph
Re: Newest firmware for H3-10.0-E, EP11 and W6
Posted: Wed Oct 22, 2025 9:30 am
That's what I see when I look at the update portal, you are right up to date.
Just to add the firmware is always changing, on the newer products it moves quickly and on more mature products it will only have a few minor increments over time.
If you are a lot behind or are experiencing problems it is worth getting updated, I tend to work on the basis of 'if it isn't broke don't fix' as some of the newest firmware releases can (sadly do) cause problems so best to stay behind the bleeding edge.
