Turning off discharge
Posted: Thu Apr 06, 2023 1:50 pm
by eterrace
Not yet a Fox owner - but about to pull the trigger provided it has one key feature that I can’t find on the (not great) documentation. Is it possible (with HC1 inverter and ECS batteries) to stop the batteries from discharging? I have an EV without any Smart Control on the charger except for a timer and I do not want my EV to charge from the battery, only from the grid. I simply want to make sure that if I have my EV charging on a cheap overnight rate then I can stop the ESS from discharging. Is this what the force charge setting does in practice? Thank you for any help, this would be a deal breaker if the function isn't there.
Re: Turning off discharge
Posted: Thu Apr 06, 2023 7:07 pm
by APfox
Not an EV owner here, but there is a nice video on youtube about it:
so it should be possible yes.
Posted: Thu Apr 06, 2023 7:33 pm
by eterrace
Amazing - thanks.!! That video was just what I was looking for.
Posted: Fri Apr 07, 2023 10:58 pm
by calum
It absolutely does do what you'd expect. The only annoyance is that there are only two Force Charge windows to play with but this can be worked around.
