Charge From Grid Not Deselecting
Posted: Tue Oct 14, 2025 5:07 pm
by SolarJunkie
Good evening all,
I am just wondering if anyone knows of a bug which causes the charge from grid function to not switch off when deselected?
I have set time schedule 2 to between 2 and 3pm and the schedule is disabled, however, the batteries appear to still be charging between these periods.
Work mode is feed-in priority.
Inverter is H1-5.0-E
Master 1.46
Slave 1.02
Manager 1.44
Re: Charge From Grid Not Deselecting
Posted: Tue Oct 14, 2025 5:22 pm
I’m not aware of any bugs - but if you are using the charge periods - check after you have de-selected it, that you are pressing the ‘save’ button at the bottom if you are using the old app, or if using the latest app click ‘Submit’ top right when you have deselected it to send the changes.
If you close the app and come back in again, the switch should be off.
If it is the scheduler you are using you must click ‘submit’ in the top right after making changes to send them to the inverter.
Posted: Tue Oct 14, 2025 5:26 pm
by SolarJunkie
Thanks for the quick response.
I saved several times and the switch was off...
I have now set the time to 14:00-14:00, so if the scheduler isn't turning off, there should be no charge time, so I will monitor.
