Ideal System Minimum SoC and Battery Reserve Capacity levels
Posted: Thu Oct 09, 2025 5:37 pm
I have only recently (3 days ago!) installed solar panels and FoxESS EP11 battery and H1 Hybrid Inverter and am gradually coming to terms with its usage.
I am unfamiliar with System Minimum SoC and Battery Reserve Capacity (and certainly not the detailed technical details that go with them) but I understand the basics and I am a little concerned that much of what I have read elsewhere implies that Min SoC should be at around 20% (for ensuring good battery life) and this seems to go hand in hand with reserve capacity. Indeed, the pre-set levels for both on the Fox app were set at 20%. However, reading several of your associated replies on this forum re SoC, you recommend 10%. This is preferable for someone (like me) wanting to use as much battery resource as possible rather than the grid, but conflicts with general advice - and the Fox app!
Which is most appropriate please, and why?
