battery over voltage
Posted: Fri Oct 03, 2025 9:01 pm
by adamski99
My battery cutout due to over voltage last weekend while we were away, got a CODE-194 and the battery turned itself off.
I turned the inverter and battery off then on again and its working fine again but I'm a bit concerned that an over-voltage could be triggered.
These are the firmware versions of the KH9 inverter and EP11 battery
Is this a known issue, any ideas on what to do?
Cheers
Re: battery over voltage
Posted: Sat Oct 04, 2025 9:13 am
Your battery firmware is up to date, the inverter slightly behind so worth updating.
The battery voltage is within range so this is more likely a cell balance problem which sometimes occurs on newer installs particularly if they haven’t had many full discharge/charge cycles (from grid) - best to do a full discharge and charge cycle from grid (a couple of times over the next few weeks), most of the balancing is done as it passes 95% to 100% but some bottom balancing also takes place so make sure your minSoC is set to 10% and that will allow the pack to learn it’s limits.
Posted: Sat Oct 04, 2025 8:07 pm
by adamski99
Thanks for the info.
The system was installed in may and it has done many full charge discharge from grid.
It's charging every night from grid between 12:30 and 5:30 and untill a few weeks ago was doing a force discharge to grid every evening as well.
How do I go about updating the inverter, should I ask my installer or can I request directly with fox ess?
Cheers
Posted: Sat Oct 04, 2025 8:19 pm
You should start with your installer as they can update it remotely for you, Fox will assist of they don’t respond (you can raise a service request in the V2 app via ‘Me’ Contact Us, Support)
