H1-6.0-E-G2 Max Connected PV
Posted: Thu Oct 02, 2025 10:48 am
When I had my H1-6.0-E-G2 installed the datasheet showed a max input power of 9000W split 4500W per MPPT. I now see the new datasheet shows the same value but also has Max PV array power of 12000W. does this also apply to inverters before the new datasheet was published? Does the inverter just cap at 6kW total power? I'm looking at adding a second inverter when adding extra panels and splitting it between them but just wanted to know the limits of a single inverter.
Physixz
Physixz
