Compatible? Fox ESS EQ4800 + H1 5.0 E1 Inverter
Posted: Mon Sep 22, 2025 9:29 am
Hello, everyone,
I'm hoping to get some advice on a compatibility issue I've run into while setting up a new battery system. I have a FOXESS H1 5.0 E1 inverter and I was planning to connect a Fox ESS EQ4800 L9-41.93kWh stack.
I've looked at the manuals for both devices and found some technical data that suggests there might be an issue, but I'm not sure how critical these differences are.
Here are the specs from the manuals:
My Inverter (FOXESS H1):
-Max. Battery Voltage: 450 V
-Max. Charge/Discharge Current: 40 A
The Battery Stack (Fox ESS EQ4800-L9 41.9KWH):
-Operating Voltage Range: 365.4 V - 463.7 V
-Max. Charge/Discharge Current: 50 A
I have two main concerns, and I'd appreciate it if someone with more experience could clarify them for me:
1. Voltage: The battery's maximum voltage of 463.7 V is slightly higher than the inverter's maximum rating of 450 V. The difference is only 13.7V. Is this small difference negligible, or does it pose a risk?
2. Max Current: The battery can supply a maximum current of 50 A, while the inverter is rated for 40 A. My assumption was that the inverter would only ever draw a maximum of 40 A, so the battery's higher current rating would just provide extra headroom and not be an issue. Is this correct, or is it a more serious problem?
Any guidance on whether this is a safe and workable combination would be a huge help. I don't want to risk damaging my equipment.
Thank you in advance and greetings from sunny Portugal!
Henrik
Henrik
