How do I stop battery exporting in evening?
Posted: Tue Aug 26, 2025 6:18 pm
by Finning2011
Hi my battery charges fine in the day but then exports in the evening /overnight when I use the most electricity and I can’t work out how to stop this? What do I need to do so it only exports when battery is full but only sends a small amount and not most of the battery? Thanks
Re: How do I stop battery exporting in evening?
Posted: Tue Aug 26, 2025 6:28 pm
Can you post some images / graphs of the problem and also provide the inverter and battery model numbers/capacity - you would expect the battery to discharge to power the house load once the sun goes down so we need to understand what you mean by send a small amount.
Posted: Tue Aug 26, 2025 7:04 pm
by Finning2011
Not quite sure what to send, we have it on app as self sufficient but seems to export to the grid in the evening when we are home and our usage is higher and ideally don’t want to export evenings
Posted: Tue Aug 26, 2025 7:43 pm
I’m not seeing any grid export on that graph, but that is only a partial day
If you click on the day at the top and select yesterday it will show a full 24 hours, if you can capture a screen shot of the graph and the battery state of charge (you may need to scroll up the screen to show both)
