AC1 in addition to existing H1 Inverter
Posted: Sat Aug 09, 2025 1:08 pm
by CumbersomeZucchini
We currently have a 4kw pv array attached to an H1 3.7 inverter with 3 hv2600 batteries (V1 batteries - version C).
Have just taken an AC1 5kw inverter and 7 HV 2600 batteries (V1 batteries - Version D) out of another property and was wondering, if I had this fitted to our property alongside what is already there, is it possible to make the AC1 and H1 inverters work together so we are always charging / discharging in an optimal way.
Thanks in advance for any advice.
Re: AC1 in addition to existing H1 Inverter
Posted: Sat Aug 09, 2025 9:59 pm
by Will
Sadly, there is no supported way to link the older style inverters. I've serially connected the old style before but it's not really a great solution. The best way forward would be to upgrade both your inverters to two x H1-gen2, which support parallel mode.
I made a video about it here:
Posted: Sat Aug 23, 2025 11:27 pm
Thanks for the info.
Am I right in thinking the Gen2 inverters could take the full 8 HV 2600 batteries that the BMS supports?
I notice the battery voltage max on the specs of the H1 Gen 2 is 480v whereas on my H1 Gen 1 the max voltage is 450v.
Regards,
John
