Charging Schedule based on Conditions.
Posted: Thu Aug 07, 2025 9:16 pm
by ThSin
HI All,
new to Fox and batteries in general, only had my system installed last week.
So far so good and it's running ok. Currently I manage to charge via solar during the day and have no need to charge overnight. However as days get shorter I would like to setup the system to charge overnight so I can start the day a bit higher than I do now, to ensure I don't run out of batterie and that I don't need to use grid energy during the day.
What I am trying to setup is:
To charge between 2am and 7am up to 70%, so once the sun comes out I have room to top up with solar power but on the other hand I have enough power even if the sun decides not to show up for work :)
Is this possible, I found the app not intuitive at the moment, I guess in a couple of month it all makes absolute sense.
Any help or guidance is appreciated.
Re: Charging Schedule based on Conditions.
Posted: Fri Aug 08, 2025 11:08 am
by Will
You'll want to click on quick settings from the home plant view, then mode scheduler and then configure a slot like this.
Posted: Fri Aug 08, 2025 4:30 pm
by ThSin
Thank you Will for your quick response,
now reading it makes sense, went to mode scheduler and was a bit unsure if I should be in there, but your screenshot is brilliant.
So this max SOC limit is only valid until 7 and then is defaulting to the setting on the main screen.
Might be a silly question, what does the min soc on grid would change, i.e. changing this to 50%, or is this setting for the discharge mode?
Posted: Sat Aug 09, 2025 10:01 pm
by Will
Min Soc on grid should normally be 10% like minsoc, you have them both at 10% unless you're setup to use backup power, in which case min soc on grid reserves power just for power cuts.
