New Setup, External Equipment, Where to start?
Posted: Mon Aug 04, 2025 3:47 pm
						Hi All,
I'm trying to wrap my head around what I need to get HA/Modbus up and running. I have my HA setup already running and would like to add Modbus to the fold but I'm falling over on what I need to purchase.
I have read the Github FAQ over a few times but I think my setup complicates things (or could just be me overthinking)
All my equipment is external, I have a KH10 Inverter. There is power on the other side of the wall to where the install is so can drill a hole for that but what cables should I be running?
Here is where my knowledge is failing.
Outside (Inverter -> Wiring??) Inside ( -> USR-TCP-410s -> ethernet to homeplug -> HA Box )
As the wiring would be going external should I use a certain cable? For this it could also need to be upto 3M in length as might want to locate in a nearby cupboard. Router is on the other side of the house so no easy to just run an ethernet cable.
I like the USR-TCP-410s as it can just be plugged in without exposed wires like the Elfin unless I am missing something with this?
Picture is of the inverter.
All help much appreciated.
Cheers
Cheers
