Vmini
Posted: Thu Jul 31, 2025 8:27 pm
by stephen
Hello everyone,
I need some information. I know it's indicated in the technical documentation, but I'm not knowledgeable enough to be sure. I'm installing a solar tracker on the second MPPT of my H1-G6-E-G2 inverter. Will 4 24V solar panels be enough to start the inverter? I don't quite understand its minimum voltage.
Thank you for your answers.
Re: Vmini
Posted: Fri Aug 01, 2025 8:26 am
The specs say 75V minimum startup, i’ve found that 3 panels @ 32V (96V) is close but it does work, but I recommend adding another panel if at all possible particularly if there is shading as it might reduce a panels output.
In your case 4 * 24V panels is the same (96V) so it should work ok but if you have any option to increase the number of panels I would do so.
Re: Vmini
Posted: Fri Aug 01, 2025 8:29 am
by stephen
Got it, I am limited by size so I will look for slightly lower power panels that are smaller to add one or two more, thank you.
Re: Vmini
Posted: Mon Aug 04, 2025 5:44 pm
by WyndStryke
Have you looked at high voltage panels?
For example, the REC Alpha PureR or PureRX. The Pure-R is around 50v. The extra voltage should help. If I recall correctly the RX is physically a little bigger than the R so depending on the space available, one might be better than the other.
Re: Vmini
Posted: Mon Aug 04, 2025 5:47 pm
by stephen
I'm doing some research, but I don't understand all the data. I recently found some panels with this as an indication: Voltage at MPP* Umpp [V] 44.06.
Does that mean it outputs 44V when operating? :?:
