Issues with app always showing battery discharging and Mode scheduler set up
Posted: Mon Jul 14, 2025 6:15 pm
i'm have a few issues with the App
Firstly the APP seems to recently now always be showing as if the battery discharging at a low wattage eg 37w discharge. I have a energy monitor which also has a ct on the invertor feed supply so i know when its actually discharging and charging etc so not sure why its continually showing discharging ! This has only started happening over the last couple of weeks.
I have shutdown the invertor and isolated the batteries and then reset and started up again , which has sorted some other APP issues in the past but not this time.
also
I have the following setup under the Mode Scheduler.
i'm on Intelligent Octopus Go with a low rate tariff for car charging which also charges my battery , if required.
also
I'm on Outgoing Octopus with fixed rate export.
My mode scheduler has been set up with a forced discharge set for late evening to min SOC 15%
and a forced charge during the 0100 to 0500 cheap rate during the car charge period.
Up until a few weeks ago this has been working well but now is intermittent working.
i also tried adding in additional schedules 1 for additional charge period and also an additional forced discharge - they dont work at all - these were out with the times on the others so shouldnt have been a conflict. Is there a limit on number of Schedules that can be setup that i'm not aware of ?
lastly my ESS cloud site wont load up on either of my apple PCs - again hasnt been an issue with this in the past
appreciate any assistance and advice
thanks
Martin T
- Daily cha
also
also
thanks
Martin T
- Daily cha
