Best way to split 24 panels across 3 strings?
Posted: Sat Jul 12, 2025 1:15 pm
My install is ongoing (long story), and so far we have 12 panels on an East-facing roof, and 6 panels on a West-facing roof. These are connected to a KH8 inverter. The panels have been split into 3 strings, 2 strings of 6 panels each on the East-facing roof, and 1 string of 6 panels on the West-facing roof.
The 3rd stage of the install (don’t ask why it’s run to 3 stages!) is the install of 6 additional panels on the West-facing roof.
Although I trust the installers, I’d also like to understand for myself what the best way will be to split these 24 panels across the 3 available strings? The East-facing roof shouldn’t ever suffer from any shading, whilst the West-facing roof is likely to have some shading towards the bottom gutter edge.
I’ve seen some references to string power generation limits of 3300 watts and 5500 watts. The user manual seems to suggest 8000 watts, if I’m reading it correctly (Max. MPPT input power (Per MPPT)). Depending on which is correct, this would dictate the max number of (450W) panels per string - 7 panels if 3300 watts, 12 panels if 5500 watts, or 17 panels if 8000 watts.
Consequently, is my rationale correct in thinking that it would probably be best to run all 12 panels on the East-facing roof on PV1, and then run the 12 panels on the West-facing roof as 2 strings PV2 and PV3 (2 rows of 6 panels each) to mitigate any shading from the lower row? This would only work though if the string limit is >5400 watts (i.e. 12 x 450)
