Dual Hybrid Inverter Setup with Single Battery
Posted: Fri Jul 11, 2025 12:18 am
I would like to know if it is possible to use the following setup:
2x Foxess KH10 Single Phae Hybrid Inverter
1x HV Battery connected to both inverters
Basically i only have single phase available and with home demands increasing, heat pump, ev chargers, etc.
The 10kw available from 1 inverter will be rather limitative in a short time, so i was looking to place two inverters in order to scale the output capabilities to a maximum of 20kw.
The thing is for now i would like to use just one battery, will i be able to connect it to both inverters while they are in parallel, master slave configuration and be able to get output of the battery at 20kw max, balanced load between both inverters?
Or is this balance only possible with one battery for each inverter?
