Help Configuring Inverter Settings
Posted: Thu Jun 26, 2025 2:59 pm
These forums have been an excellent learning tool, so thank you, however I am still struggling with the app settings, and hope I can get some help.
I might be asking for the impossible, but here goes...
Inverter KH10.5
Battery EP11 (20 kWh)
PV 15.7 kWhp
So I would like to configure the app to:
1) Charge batteries during off-peak hours (00:00–07:00).
2) During the day, use battery power to run the house and export all solar generation. (If that's not physically feasible, then use solar for the house and export any excess. When solar stops generating, switch to battery.)
3) From 21:00 to 23:59, "100%" discharge batteries to both supply the house and export to the grid. (If this isn’t feasible, discharge the batteries during 00:00–07:00 instead (same rate) and run the house on off-peak grid power overnight. Still aim to use battery power during non-solar hours.)
4) Repeat daily.
Many thanks!
Inverter KH10.5
PV 15.7 kWhp
4) Repeat daily.
Many thanks!
