Wifi not working / conflicting with inverter
Posted: Tue Mar 07, 2023 2:46 pm
First off, I'm not massively tech savvy, so apologise if I'm not posting in the right place.
I have a Fox 3.7kwh inverter (with 12 x 395 JA Panels) and everything was working fine, app was showing the data correctly and everything
Then one day my internet went off. Re-connected it, but nothing connected back up to the app on my phone, although the display on the inverter showed it to be working perfectly. The app showed nothing
Got the instructions out, connected up to the W-******* wifi on the dongle and entered 192.168.1.1 as it says and re-connected to the home wifi by clicking on it in the Wifi SSID box and entering the password
Hey presto, back up and running on the app
Only problem is, now nothing else in the house will work using the home wifi. Not phones, not game console, not laptops / tablets, ring doorbell, amazon fire, nothing. Sometimes does intermiterntly but in general nothing
Got the (several now) internet engineer out to look at it. No faults found. The last one who came out suggested looking at the channels that both the router and the inverter were transmitting from and both showed channel 11, so he went in and changed the router channel to number 5, and everything sprung back into life...........for about 10 minutes and then shut down again. On closer inspection, the inverter had jumped to channel 5 also, and not stayed on channel 11. He looked at the 192.168.1.1 and said he could not see a way of making the inverter stay "static" on the channel selected, so could not help (I'm lost here by the way). He even attached an ethernet cable from the inverter to the router and the same thing happened in that it followed the channel
Does anyone know why what the inverter is doing should be blocking all other devices. I'm guessing something changed when I re-connected after the initial internet outage, but don't know what
Can anyone help at all with any suggestions please, as we are stuck with what to do now
Thanks in advance
Thanks in advance
