Battery - parallel addressing failure
Posted: Sat Apr 26, 2025 1:25 pm
by Woodsi
Have just commissioned our system which includes a Fox EP5 battery. This is showing a ‘parallel addressing failure’ and not charging/discharging with the inverter.
I can’t find any details of what this error means or how to solve it, so any suggestions very welcome!
Re: Battery - parallel addressing failure
Posted: Sat Apr 26, 2025 4:06 pm
Do you have 2 inverters in parallel ?, that usually happens when it is configured to run in parallel and the wiring or addresses have not been set correctly.
Posted: Sun Apr 27, 2025 8:13 am
by Woodsi
Nope, it's just one inverter
Dave Foster wrote: ↑Sat Apr 26, 2025 4:06 pm
Hi Dave, thanks for the quick reply. I've found the issue - the blank plugs weren't inserted into the data sockets intended for parallel battery installation. Once the had been inserted and the battery re-started, the error went.
Posted: Sun May 25, 2025 11:37 am
by Bertulek
Hello. I have the same Problem at my Fox Ess EK5. My two caps are on and screwed on, but I have the same problem.
Posted: Mon May 26, 2025 9:59 am
by Will
highly likely missing the two rj45 bypass plugs are not fully installed. They get missed all the time.
Posted: Tue May 27, 2025 3:58 pm
by Bertulek
OK. Sorry, but where do they go and can I find them in the box? Is it on the inverter?
Posted: Tue May 27, 2025 3:59 pm
by Will
They come in the battery box. Two small connectors. They look like blanks but they have a small wire in them
Posted: Tue May 27, 2025 8:00 pm
by Bertulek
I found one. Should there be two? Where is the jumper between which pins? Should they be link in and link out?
