LV5200 Battery 3 and 4 not showing capacity LED
Posted: Thu Apr 10, 2025 4:26 am
Hi there,
I installed 2 LV5200 as part of a Solar install in Feb 2023.
All was good and they operated as expected.
I then got 2 more in Oct 2024. They are all purple labels.
While all the LED seem to be functional on #3 and #4 they only have a single flashing LED in operation. Is this a firmware issue, I have read somewhere about a dormint BMS where the individual charged the batteries up directly using a 48V PSU, although I don't think this is it.
I do have the capacity as I have done tests charging and discharging from 20-90% using a specified rate of charge from the inverter.
They currently appear as Pylontech on a Sofar HYD-6000-EP. I took a voltage measurement this evening on the output of the 4th battery and it read 54V (the system was charging at the time, SOC was showing 92%).
I know you can't really mix batteries and bms but if I was to purchase the 2m cable that goes from the Master to the Inverter, not the link power cable between batteries. Would it be possible or could the output voltage from battery #4 be used to power a 48V DIY Lithium battery.
I also have 4 sockets 230V that are connected to the EPS of the inverter and this supply power if the inverter goes off grid. That would be another option to plug in a charger with a high current output.
The 4 batteries would then act like a buffer charging the plugged in DIY one. Thanks for any comments
