Insurance have paid out for replacement.
Thank you. I am now in a position to replace the foxess all in one 5kw hybrid inverter with 10.4kw. The insurance has paid out. I would like to stick with foxess as it’s all worked well from day one.
I am going to put more panels on the roof so they get the sun in the afternoon.
Cann I have 4 on one string and 8 on another. JA Solar panels 545w out put.
I would like a 6kw inverter instead of the 5kw one I have with the kit I have just now. I would also like to increase the battery storage to around the 16kw but also would like to be able to add more if I need.
If it’s not too much trouble could one of the members recommend a set up and where to purchase from. I take it vat isn’t applicable if a registered solar installer fits all the stuff?
Thank you. Graham Murray.
Re: Insurance have paid out for replacement.
Cann I have 4 on one string and 8 on another. JA Solar panels 545w out put. - Yes you can have two strings, 4 being close to the smallest I recommend
I would like a 6kw inverter instead of the 5kw one I have with the kit I have just now. I would also like to increase the battery storage to around the 16kw but also would like to be able to add more if I need. You will need to submit an updated G99 application for the inverter and battery change
If it’s not too much trouble could one of the members recommend a set up and where to purchase from. I take it vat isn’t applicable if a registered solar installer fits all the stuff? You will need to installer to purchase and install the system, I don't believe you'll get VAT relief if you buy the hardware. In terms of where to buy, checkout ecosuperstore and sunvolt
Thank you. Take care.
