FoxESS to Home Assistant Integration Options (H1/AC1&AIO)
Posted: Fri Oct 14, 2022 10:33 am
by Will
As FoxESS has grown its market share globally, it's been under active development from its community of developers who want to extend its functionality, reporting and automation capabilities.
It's now possible to integrate your H1 series FoxESS solar/battery system with Home Assistant in four ways detailed below:
1. FoxESS Cloud Integration https://github.com/macxq/foxess-ha
By far the easiest to setup, this integration uses your FoxESS cloud app login details to poll the FoxESS Cloud every 5 minutes.
Pros:
  • Easiest to set up
  • No additional hardware or cabling needed
Cons:
  • Relies on the cloud being available
  • Slow polling rate, data polls between 5-15mins
2/3.FoxESS RS485/LAN Modbus https://github.com/StealthChesnut/HA-FoxESS-Modbus
This is the most advanced integration, requires a network cable to be installed into the inverters LAN port or can use a USR-W610 RS485 to lan adapter to convert RS485 to a wifi accessible web server which Home Assistant can connect to and poll in near realtime.
Pros:
  • Local polling, no reliance on the cloud
  • Realtime polling of inverter data
  • Allows for better automation as the data is realtime prividing better triggers
Cons:
  • Additional hardware (USR-W610) or Network Cable required
  • Latest Firmware required for direct LAN interface
4.FoxESS API with Cloud/TCP control https://github.com/dmarjoram/Roses.SolarAPI
This integration uses a combination of cloud commands and TCP commands via the modbus address to change work mode, set force charging windows and set MinSoC's.
Pros:
  • Offers features not in other integrations
  • Offers local and cloud commands
  • Lightweight
Cons:
  • Relies on the cloud being avilable for some features
  • Requires docker hosting knowledge
  • Requires exposed modbus address for inverter which might required additional hardware or cable depending on solution
Re: FoxESS to Home Assistant Integration Options (H1/AC1&AIO)
Posted: Wed Feb 22, 2023 7:45 pm
by Ched
Just wanted to say thanks for this forum and your posts.
I installed Home Assistant on a RPI3 I had kicking about and bought a RS485 to USB converter and wired it up and added the code as required and it worked perfectly. It's so much better than the Fox App.
Posted: Sat May 27, 2023 11:17 pm
by canton7
Would it be possible to recommend foxess_modbus instead of ha-foxess-modbus, and avoid recommending the USR-W610?
Posted: Sun Oct 01, 2023 2:56 pm
by muscar
Ched wrote: ↑Wed Feb 22, 2023 7:45 pm Just wanted to say thanks for this forum and your posts.
Hey I have recently purchased a solar system with a Fox Inverter H1-5.0-E and I am a bit frustrated of the fact that it does not show live data but more of a snapshot of what happened 5 minutes ago. I was trying to get Home Assistant integration with my inverter but I am not sure what pieces I need to buy in such a way that it does not impact the current setup of the inverter in any way.
I can see that my LAN port is being used on my inverter that is connecting to a clamp on the grid cable connection and I have a WIFI module installed on it. Is there any way that I can leave the invertor in that setup but also extend it so I can connect to it from Home Assistant and pull data down?
Have also seen the IP address of it on the network but when I connect to it there is a web interface that allows me to change the following:
  • Set-up net
    Local upgrade
    Set port number
    Change AP Password
    Network Configuration
Posted: Sun Oct 01, 2023 3:44 pm
by calum
Have a look at the FoxESS Modbus integration here https://github.com/nathanmarlor/foxess_modbus/
Particularly have a read of the wiki pages about connecting to your inverter.
If I were you I'd look into an RS485 interface, they are not particularly hard to connect and they are more capable and reliable than the direct ethernet method.
Posted: Tue Oct 24, 2023 5:00 pm
by JRascagneres
Hi guys! Looking at getting FoxESS batteries installed. Can you control when they charge / discharge on HA?
Posted: Tue Oct 24, 2023 5:51 pm
JRascagneres wrote: ↑Tue Oct 24, 2023 5:00 pm Hi guys! Looking at getting FoxESS batteries installed. Can you control when they charge / discharge on HA?
Yes, you have to connect to the inverter via RS485 and then you get access to sensor data and you can control charge periods and many other settings.- i’ve linked the integration below as it documents the installation and connection.
Posted: Tue Dec 12, 2023 9:14 am
by MadWayne
I had the Ethernet version working until the Ethernet port was turned off.
Loved it with uptodate information, now trying to get the the ra485 mod to work and struggling.
With the rs485 usb module HA seems to freak out on the PI4.
So must be missing something very basic as I can see others with it working.
I bought the usb module recommended, maybe this isn’t set up in HA correctly.
The PI4 only stops working when it’s connected to pins 3 and 4 which are the rs485 pins on the H1 inverter, with it not connected to the inverter HA works.
Thanks for listening
Posted: Tue Dec 12, 2023 10:55 am
What were you using on your Pi to connect to the modbus, was it the old StealhChesnut (using an include in your configuration file with modbus.yaml) or Nathan's newer integration (https://github.com/nathanmarlor/foxess_modbus)
On the older version the modbus timeouts could definitely block your HA from starting/stopping if not configure correctly.
Probably worth as a start, remove whichever modbus integration your are using and see if the Pi will start up with the modbus adaptor plugged in with the cables connected.
Inver Pin 3 (RS485B) should be connected to the B pin, Inverter Pin 4 (RS485A) should be connected to the A Pin.
Assuming it starts ok, I would recommend using Nathan's integration I linked above, it's much easier on resources.
How connect FoxEss p3-5.0-SH at Home Assistant ?
Posted: Fri Jan 16, 2026 4:47 am
by florinm
Hi everyone!
I have a P3-5.0-SH inverter with battery that I want to connect to Home Assistant. I tried with FoxEss ModBus integration, but I don't know which option to choose: connection via LAN, USB, Ethernet.
I tried via LAN, but I get the message "Error connecting to your inverter. Details: Inverter model not supported: 'P3-5.0-SH'"
I also want to know if I need to purchase another external communication device.
Thanks!
Re: How connect FoxEss p3-5.0-SH at Home Assistant ?
Posted: Fri Jan 16, 2026 11:51 am
florinm wrote: ↑Fri Jan 16, 2026 4:47 am Hi everyone!
Thanks!
You shouldn't need another adapter, just connect using LAN - the P3 isn't supported directly by the integration yet - there is a pull request pending, and so if you install the latest beta v1.14.0b3 and are able to make a few small code changes as detailed here https://github.com/nathanmarlor/foxess_modbus/pull/954 you will get it working.
Posted: Fri Jan 16, 2026 7:19 pm
by florinm
it worked! thank you!
Posted: Mon Mar 30, 2026 11:10 pm
by Billybob1969
Hi I'm using a waveshare rs485 to wifi/ Lan module, connected to a kh10 inverter and using home assistant in a pi5. I'm struggling to retrieve data from the inverter, I've not yet had a successful response. Do I need to have Foxess support enable a hidden setting to enable modbus comms? I've followed all the steps in the github.com repo from Nathan Marlor but no joy, I get unavailable or unknown sensor status and can't connect at all due to timeout via the foxess modbus hacs integration. I've tried swapping the cables (a+b) but no difference. Why can't I establish a connection??
Thanks!
Posted: Sat Apr 11, 2026 12:03 pm
by nicois
A new option for controlling your inverter from Home Assistant is an integration I have written. It's mentioned in a sibling topic but I believe it's worth considering, as it makes it very easy to properly charge and discharge correctly. While it can integrate with a modbus system it primarily works with the cloud API, making it very easy for anyone with HA to use.
https://github.com/nicois/foxess-control
Posted: Mon Jul 06, 2026 6:00 pm
by distalcafe
nicois wrote: ↑Sat Apr 11, 2026 12:03 pm A new option for controlling your inverter from Home Assistant is an integration I have written. It's mentioned in a sibling topic but I believe it's worth considering, as it makes it very easy to properly charge and discharge correctly. While it can integrate with a modbus system it primarily works with the cloud API, making it very easy for anyone with HA to use.
Thanks, that worked for me with my AIO (battery only, no solar and no modbus).
It displays the entities I want at a quick glance, and when I have time will be looking to add some automations to make use of the Octopus Intelligent Go cheap daytime slots when the car is charging.
Posted: Mon Jul 27, 2026 7:44 am
by Deeno7471
everyone,
I'm looking for someone in the UK who offers a paid remote setup for Home Assistant and Predbat.
My system is:
• FoxESS KH10.5 inverter
• 3 × EP11 batteries (approximately 31 kWh)
• Fox EPS Box
• Intelligent Octopus Go tariff
I don't currently have Home Assistant installed and would like someone to:
• Recommend the best hardware (I'm happy to buy a Home Assistant Green or mini PC)
• Install Home Assistant remotely
• Connect my FoxESS inverter and Octopus account
• Install and configure Predbat
• Test everything in monitor mode before enabling automatic battery control
I'm happy to pay a reasonable fee for an experienced installer. If you've set up a similar FOXESS system, pleas
* in touch. Thank you!
Posted: Mon Jul 27, 2026 3:24 pm
by Deeno7471
everyone,
My system is:
• Fox EPS Box
Posted: Tue Sep 15, 2026 2:08 pm
by AndyJ56
Hello - did you find anyone to do this? I have just done pretty much exactly what you are after and am really happy to share all the info and tips with you. You can now use Predbat via Fox Cloud but I went for the direct integration route. Which for your inverter would mean either running a ethernet cable to it or using a wifi adapter.
You might also try these guys - https://spectrumenergysystems.co.uk/ - they *might* offer a service. They actually do what you want as part of all their domestic installs which is pretty cool.
Shout if you want any specific info. Predbat has been great so far - pretty much zero or negative import bills now.
