Inverter Grid Charge capped since firmware update
Posted: Tue Mar 11, 2025 10:07 pm
First post so apologies for any nonsense!
I've recently had my installer update my KH7 firmware (not sure what from), but it's now showing:
Master: 1.41
Slave: 1.01
Manager: 1.39
(Also I couldn't find this on the app or web portal - I've found the battery firmware versions, but not the inverter - if anyone could point me in the direction, as ChatGPT didn't help!)
Onto the issue - before the firmware update, I used to charge my batteries and EV at the same time (Octopus Intelligent Go tariff) - and I would pull a peak of ~13.5kW from the grid while the EV and batteries charged, then usually drop to 6-7kW once the batteries had finished charging (or EV had).
Since the update, it appears that the max power I can now draw from the grid is ~7.8kW, so I'm only charging the EV, or the batteries, but not both at the same time.
Is this a setting I can tweak? It hasn't been an issue so far, but I can imagine if I'm doing a long drive, and have had a lot of drain on the batteries for a day, then the batteries won't fill up if the EV charging takes the entire "enable charge from grid" window.
Master: 1.41
Slave: 1.01
Manager: 1.39
