Fox Cloud Refresh Frequency
Posted: Thu Feb 13, 2025 9:02 pm
by vmode
Hi, my Fox Cloud app used to refresh every 5 minutes or so. However recently it seems to be around every 10 minutes. Any idea why this would have changed? I can't seem to find any setting to control it.
Re: Fox Cloud Refresh Frequency
Posted: Tue May 20, 2025 2:12 pm
by Will
There is no control over the poll rate but fox have said it will in the near future support near realtime updates.
Posted: Sun Jun 15, 2025 11:24 pm
by Bugs
Did they give any time frame for real time data?
‘In the near future’ is a little vague.
Posted: Mon Jun 16, 2025 8:53 am
by Will
I believe, based on my notes, that it should be any week now but i'll follow up with fox to see if they have a better eta.
Posted: Thu Nov 20, 2025 8:29 pm
by MichaelA
Any update if near realtime is available now?
Monitoring system performance with VPP is very difficult with the current 5 min delay
Posted: Mon Dec 08, 2025 11:53 am
by slicksolar
Is there any more news on the real time update?
Posted: Sun Dec 21, 2025 7:44 pm
by WyndStryke
I seem to remember reading somewhere that the cloud refresh period can be adjusted if you have a (very recent) -WL inverter (the ones with integrated wifi & built-in modbus), albeit with an installer-only setting rather than a use-configurable setting.
Posted: Sun Dec 21, 2025 10:18 pm
by slicksolar
Yes I've heard the WL variant will have quicker refresh rates for sure but was hoping the older data loggers would get an update too. If not, then Modbus route it is. Just didn't want to spend on more hardware if Fox was planning to increase the refresh rate anyway by firmware update. I have a feeling this may not be the case. Hope I'm wrong though.
Posted: Wed Jan 14, 2026 12:04 pm
by slicksolar
Great news regarding the 5 second refresh update.
https://www.youtube.com/watch?v=Xfib0pAcO4Q
Will we as end users ever get the ability to update the firmware form initiate one ourselves?
Posted: Wed Jan 14, 2026 1:50 pm
by MichaelA
Wow great news thanks
With my Inverter being a H3-Smart
Version_Master:1.33
Version_Slave:1.00
Version_ARM:1.20
So the video shows that you have to be at these firmware releases - see attached
When they say the H3 Smart Manager needing to be at version 1.21, are they referring to thte Master, Slave or Arm version
My Data Logger version is V2.06. Does that mean I need to upgrade the data logger firmware to 2.07?
Posted: Wed Jan 14, 2026 2:02 pm
by WyndStryke
For some reason, sometimes Manager is called Manager, and other times it is called ARM. I don't know what the latter stands for, but it's the same thing.
Assuming you have an inverter where the datalogger is integrated rather than being a dongle, yes sounds like you need updated firmware for it.
Posted: Wed Jan 14, 2026 2:06 pm
by MichaelA
So I need to upgrade both
  • my ARM (inverter manager) should be upgraded to version 1.21, and
  • the Data Logger firmware to 2.07.
Is that correct?
Posted: Wed Jan 14, 2026 2:10 pm
by WyndStryke
Yes
Posted: Wed Jan 14, 2026 2:20 pm
by MaterialBarracuda48
Master/Manager/Slave here from Dave
viewtopic.php?p=12046#p12046
Posted: Fri Jan 16, 2026 11:49 am
by slicksolar
Had the update done. All working well, much happier with refresh rate. Do we know if the API limit will be increased so we can get this update rate into things like Homeassistant?
Posted: Fri Jan 16, 2026 11:56 am
slicksolar wrote: ↑Fri Jan 16, 2026 11:49 am Had the update done. All working well, much happier with refresh rate. Do we know if the API limit will be increased so we can get this update rate into things like Homeassistant?
My HA already gets very rapid updates on the main ticket items? There are some sensors that need less update speed, and some that need quicker date, and that works fine as is for me.
by WyndStryke
We can already get 10s updates on everything via modbus, and my understanding is that the 5s update in the app is only for a handful of sensors (so the majority of sensors are still on 5 minutes).
I presume they're doing it by keeping an open socket connection rather than initiating and closing down requests every 5 seconds. If that's correct, if this were to be extended to the API, they'd want to change the design rather than simply increasing the limit.
Posted: Fri Jan 16, 2026 11:59 am
WyndStryke wrote: ↑Fri Jan 16, 2026 11:56 am We can already get 10s updates on everything via modbus, and my understanding is that the 5s update in the app is only for a handful of sensors (so the majority of sensors are still on 5 minutes).
This is my understand of the new FW changes, locally the data is shown in 5secs intervals and then every 5mins they push data snapshots to the servers for long term logs (power graphs in App/and websites)
Posted: Fri Jan 16, 2026 12:00 pm
Yes absolutely correct, the OpenApi wouldn't be able to cope with the extra demand - modbus connection is the way to go for near real time.
Posted: Fri Jan 16, 2026 12:17 pm
by WyndStryke
Dave Foster wrote: ↑Fri Jan 16, 2026 12:00 pm... - modbus connection is the way to go for near real time.
There's probably even scope for increasing the refresh rate on modbus in a similar way - polling a few key sensors more frequently, and the majority of sensors at a slower rate. There's little advantage in checking SOH% frequently, for example. On the other hand, the HA database probably wouldn't appreciate a bunch of extra data for the people on RPis with SD cards & similar.
Posted: Fri Jan 16, 2026 12:29 pm
WyndStryke wrote: ↑Fri Jan 16, 2026 12:17 pm
The older modbus used to have variable polling speeds (which I liked), the current integration polls everything together which seems counter productive, but having done some modbus message timing, the extra overhead to read a bank of registers vs individual sensors is surprisingly small.
As it stands a good adaptor or LAN would probably get you down to 5 seconds polling, and tbh some of the sensors don't make much sense at that speed as you are seeing the artefacts from the inverters load balancing. For the database there is a 'sticky' option in the advanced options of the integration that allows you to slug the speed of response of update so they only report more significant changes in value.
Don't get me wrong, if someone did the work to allow user configurable polling speeds per sensor - i'd take it. ;)
