Missing Sensor
Posted: Fri Feb 07, 2025 11:22 am
by HughInDevon
I am using the NathanMarlor HA integration, version 1.13.4 (Thanks Dave!) which shows 81 entities. The ones I need for my automation project are the two associated settings for force discharge mode. I can access the Force Discharge Power, number.kh10_inverter_force_discharge_power but for the life of me I cannot find the Force Discharge Soc.
My KH10 inverter firmware versions are:
(ARM) Manager (KH10_Inverter) 1.22
Master (KH10_Inverter) 1.39
Slave (KH10_Inverter) 1.01
Maybe the ARM version is too old to show the FDSoc entity but it's odd that the FDPwr entity is present but not the other. Am I missing something?
Thanks,
Hugh
Re: Missing Sensor
Posted: Mon Feb 10, 2025 9:43 am
by WyndStryke
Some of the registers relating to force charge / discharge slots in the mode scheduler aren't readable on the KH inverters (not sure about other inverters), so the integration has no way to know.
I don't know if they are writeable however (i.e., write-only), or simply inaccessible entirely.
I implemented this in my own crude scheduler by simply monitoring the battery_soc myself and changing the work mode when the target was reached.
Re: Missing Sensor
Posted: Mon Feb 10, 2025 9:55 am
by HughInDevon
Thanks for the clarification. I have also devised my own, very crude, automation to use the normal battery soc to switch work modes. A shame that FDSoc isn’t exposed as it would be an elegant way to do it. Meanwhile I need to find out why my work mode switching away from Force Discharge failed and thus exported full, freshly charged, battery at 05:30 yesterday morning.
Re: Missing Sensor
Posted: Mon Feb 10, 2025 10:44 am
by WyndStryke
My automation to turn off force discharge looks like this (very crude as mentioned :-) ), it will be called every few minutes, plus whenever the battery soc etc changes. It has a specific section which looks to see if Force Discharge is running between 7am (when the cheap period finishes) and 9am and turns it off if so. In the afternoon/evening it will gradually let the battery draw down, alternating with a slow force discharge. During the day it will usually swap to Feed-in first, unless I'm doing a calibration run and need solar to top up to the target.
Lots of things I'd like to clean up, for example running the SoC targets from a list rather than hard wiring them into each automation, and merging the automations into a single one rather than having a different automation for each workmode.
alias: FoxESS Feed-in default during the day
description: ""
triggers:
  - trigger: time_pattern
    minutes: /15
  - trigger: state
    entity_id:
      - input_boolean.eon_next_drive_cheap_period
    to: "on"
  - trigger: state
    entity_id:
      - sensor.battery_soc
  - trigger: state
    entity_id:
      - input_boolean.foxess_calibrate_top_reached
    to: "on"
  - trigger: state
    entity_id:
      - input_boolean.foxess_calibrate_bottom_reached
    to: "on"
conditions:
  - condition: time
    after: "07:00:00"
    before: "23:59:59"
  - condition: not
    conditions:
      - condition: state
        entity_id: select.work_mode
        state: Feed-in First
  - condition: or
    conditions:
      - condition: not
        conditions:
          - condition: state
            state: Force Discharge
      - condition: state
        for:
          hours: 0
          minutes: 55
          seconds: 0
      - condition: and
        conditions:
          - condition: state
          - condition: or
            conditions:
              - condition: numeric_state
                entity_id: sensor.battery_soc
                below: input_number.foxess_calibrate_bottom_soc
              - condition: and
                conditions:
                    below: 21
                  - condition: or
                    conditions:
                      - condition: time
                        weekday:
                          - mon
                          - tue
                          - wed
                          - thu
                          - fri
                          - sun
                      - condition: state
                        entity_id: input_boolean.foxess_calibrate_bottom_reached
                        state: "on"
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 15
              seconds: 0
          - condition: time
            before: "23:30:00"
            below: 26
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 20
              seconds: 0
          - condition: time
            before: "23:00:00"
            below: 31
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "22:30:00"
            below: 36
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "22:00:00"
            below: 41
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "21:30:00"
            below: 44
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "21:00:00"
            below: 47
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "20:30:00"
            below: 51
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "20:00:00"
            below: 55
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "19:30:00"
            below: 58
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "19:00:00"
            below: 61
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "18:30:00"
            below: 64
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "18:00:00"
            below: 68
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "17:30:00"
            below: 71
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "17:00:00"
            below: 73
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "16:30:00"
            below: 75
      - condition: and
        conditions:
          - condition: state
            for:
              hours: 0
              minutes: 25
              seconds: 0
          - condition: time
            before: "16:00:00"
            below: 78
      - condition: and
        conditions:
          - condition: state
          - condition: time
            before: "09:00:00"
            after: "07:00:00"
actions:
  - action: select.select_option
    metadata: {}
    data:
      option: Feed-in First
    target:
  - choose:
      - conditions:
          - condition: state
            entity_id: input_boolean.foxess_calibrate_today
            state: "on"
          - condition: state
            entity_id: input_boolean.foxess_calibrate_top_reached
            state: "off"
          - condition: template
            value_template: >-
              {{ states('sensor.solcast_pv_forecast_forecast_remaining_today')|
              float > ((100.0 - (states('sensor.battery_Soc') | float)) *
              (states('sensor.bms_kwh_remaining') | float) / 100.0 ) }}
        sequence:
            metadata: {}
            data:
              option: Self Use
            target:
    default:
        metadata: {}
        data:
        target:
mode: single
Re: Missing Sensor
Posted: Mon Feb 10, 2025 11:15 am
by HughInDevon
Thanks for the code. Looks very interesting! I will happily post mine when I finally get it working. Which I can't do just at the moment as good 'ol Fox are updating my firmware! :D :D :D
