Inverters and PV info
Posted: Thu Jan 23, 2025 5:40 pm
Just had a new system fitted a couple of weeks ago and I'm confused about the data sent from the inverters to the app and Foxcloud. When I log in to either the app or the cloud website I can only see the PV output of my 2 sets of panels which are connected to the hybrid inverter and not the set connected to the string inverter. So in the screenshot below, only PV1 & PV2 power levels are registering in the graph and PV3 is just a flat line at zero:
The installer explained that the app and Foxcloud only connect to the hybrid inverter (H1-5.0-E-G2). He explained that the string inverter (F3000) then sends its data to the hybrid inverter but the app needs further development before it can show the PV3 output.
Is this correct or is there some way to display the data? Can the string inverter itself be added to the app? I am a little concerned that the installer did not connect up the WiFi dongle (which came in the box) to the string inverter at all.
It would be useful to be able to see the PV outputs of all 3 of my sets of panels (are they called strings or arrays or are the terms interchangeable?) Also, as an IT admin I'm used to seeing the full picture and I hate not being able to check the inverter temperature, firmware, etc, even though I don't know what many of the details mean!
Oh yes, also, with my setup as it currently is, does the figure for "Today Yield" include all 3 sets of panels or just PV1 and PV2?
Thanks in advance
Thanks in advance
