Battery not reaching 100%. Stuck at 99%
Posted: Mon Feb 13, 2023 11:26 pm
Hi, my Mira hv25 batteries (4 of them, about 10kwh) have started getting enough sunshine to fully charge which is great.
However, when they get close to 100%, they take an awful lot of energy and just stick on 99%
Not sure how to in-line the attached photo. It shows that the soc hits 99% but charging continues around 1kw for about an hour. That’s using home assistant for the graphs. The data comes direct from FoxEss cloud and matches what I see in the app.
Temperature of the batteries doesn’t look like it should be an issue: near to 20 degrees c.
The questions
The questions
- Is this expected behaviour?
- Can I limit the max soc to eg 95%?
- If not, could I switch the inverter mode to stop charging in some way?
