Error code 222
Posted: Fri Jan 03, 2025 6:10 pm
by Kathy
Hi - I have had this error code 222 for 3 days now. I have tried everything the installers suggested but with no success. Seems they have now flagged this up to FOX but think FOX may still be closed for holidays. At least I seem not to be the only one with this problem!!?? We have only had our system a few months and this is the first problem. Wondered if anyone has any other information please. Thanks.
Re: Error code 222
Posted: Sat Jan 04, 2025 10:23 am
by Will
What hardware do you have, what is the full error code/message?
Re: Error code 222
Posted: Sat Jan 04, 2025 6:23 pm
by Kathy
Hi - I have Longi panels FOX ESS SP5 and FIX battery - if that is what you mean. I'm not too good with the technology!
Power SoC Off Mode is what it says on the Inverter
CODE 222 INVERTER is what comes up on the app on the phone.
Appreciate your interest. Thank you.
Re: Error code 222
Posted: Sat Jan 04, 2025 6:25 pm
by Will
Checkout this post code error code 222 viewtopic.php?t=1111#:~:text=Solution%3 ... %20seconds.
Re: Error code 222
Posted: Sat Jan 04, 2025 6:27 pm
by Will
It might be cold weather related to turn off the battery wait 10 seconds, turn it back on and then press and hold the enter key until it says START? and click enter until you see it accept the command. Then wait and see if the battery connects.
You'll know when the battery is connected and working because on the screen of the inverter is will say SoC = then a percentage number. If it still says N/A then you need to contact your installer.
Re: Error code 222
Posted: Sun Jan 05, 2025 2:24 pm
by Kathy
Hi = I have turned the battery off then on.
I no longer have the 222 error code which I guess is something!
The inverter display now says...
Power 0W
SoC 0%
Off Mode
followed by date and time.
Hopefully I am getting there??
Do appreciate the support. Thank you.
Re: Error code 222
Posted: Sun Jan 05, 2025 9:55 pm
by Will
you need to start the inverter by holding the Check button thrid one from the left, then when it says start? press enter twice.
Re: Error code 222
Posted: Fri Jan 17, 2025 5:59 pm
by 28Limekiln
We have an Error Code 222. Our mobile app is saying everything is off line. Has there been a software update? We have no handbooks so have no idea if there is away of removing the error code and getting back online. Having contacted the installer this morning we have had no response from them.
We have two batteries, and an inverter.
Fox H1-6.0-E-G2
Regards
Angela
Re: Error code 222
Posted: Fri Jan 17, 2025 6:34 pm
28Limekiln wrote: ↑Fri Jan 17, 2025 5:59 pm We have an Error Code 222. Our mobile app is saying everything is off line. Has there been a software update? We have no handbooks so have no idea if there is away of removing the error code and getting back online. Having contacted the installer this morning we have had no response from them.
Fox H1-6.0-E-G2
Regards
Angela
You will need to do a restart of the system - a description of the error is in this post https://foxesscommunity.com/viewtopic.php?t=1111 try the battery power off described in that post - or go with a complete system reset - there is a video here that is very helpful in identifying the switches.. https://foxesscommunity.com/viewtopic.php?t=5
