I'm new to Fox Ess with recently installed solar panels.
Question I have around the monitoring is if there is a way to view daily kwh produced by solar.
I'm able to see the total monthly value on the dashboard and also by time of day but cannot find the total for any given day.
HI
I'm new to this as well but have found if you go onto the website and them select Site Maintenance->Export a report. Chel Data Type -> All and then click Query.
This should then down load a csv file with daily data in.
Hope this helps.
Hope this helps.
It's not easy to see on the website (unless you export), the easiest way is to install the FoxV2 App - all you then do is swipe left from the picture of the 'house' and it shows all your daily stats there including production.
