Stop battery discharge (pull from grid) under heavy load.
Posted: Wed Dec 18, 2024 10:21 pm
Looking for HA automation ideas to stop battery discharge under heavy loads.
Im trying to figure out how when the oven is turned on, I can pause discharging from the battery short term and draw from the grid instead. If the oven is on, typically it would be for 45 minutes minimum and then back to batteries, unless the high load is still present, remain on grid.
Help and guidance appreciated on suitable triggers and actions
