						foxcloud2 app log on
						Posted: Fri Dec 13, 2024 9:50 am
						by LSJPC02
						i cant seem to log on to the app.first time doing it . taken over a property with fox inverter etc .. when i log on is says ..CODE; 41030 , INVALID USER..any ideas
						Re: foxcloud2 app log on
						Posted: Fri Dec 13, 2024 10:55 am
						Assuming you have been given some log in details already - make sure you are entering the username and password combination exactly as given - it is case sensitive.
It’s also better to log in to the Fox cloud website rather than the app as it often gives you better error messages - although that appears to suggest the username is incorrect - you’ll find that here
 https://www.foxesscloud.com/login
						Posted: Fri Dec 13, 2024 11:19 am
						by LSJPC02
						THANKS FOR THAT.TRYING TO REIGESTER THE INVERTER AND IT KEEPS SAYING INVALID SN CODE..PUNCHED IN THE SN CODE MARKED ON THE QR CODE ON THE SIDE OF THE INVERTETER
						Posted: Fri Dec 13, 2024 11:35 am
						by LSJPC02
						MANAGED TO LOG ON NOW VIA LAPTOP.HOW WOULD I CHANGE MY BATTERIES TO TAEIN POWER FROM THE GRID AT NIGHT AS IM ON OCTUPUS FLUX AND I DONT THINK ITS SHOWING THAT I AM DOING THAT.
						Posted: Fri Dec 13, 2024 11:50 am
						Ironically it’s much easier to set a charge period in the app, try logging into the V2 app with the same credentials you’ve used on the website, and you will find charge periods in ‘Quick Actions’ - set the time, set it to charge from grid and make sure the slider is enabled.
You can do it on the website but it’s harder to find, It’s under the ‘Device, Inverter’ screen and click the view option on the right hand side of the screen to get to the Inverter Details screen then click the top left where i’ve circled it in red next to battery - that also lets you set the charge period and click ‘save’ when complete.
						Posted: Fri Dec 13, 2024 5:22 pm
						by georgebra
						had a new router fitted at the house trouble connecting to my mobile app
						Posted: Fri Dec 13, 2024 6:18 pm
						by georgebra
						georgebra wrote: ↑Fri Dec 13, 2024 5:22 pm
LSJPC02 wrote: ↑Fri Dec 13, 2024 9:50 am
