Step 1 has to be estimating about how much power you consume at what time of year.
A Secure SMETS1 meter conveniently gathers and displays on screen your kWh consumption per month - other meters may also do this and it is worth checking, but I don't believe our current SMETS2 meter makes this available on screen. However, reading data off a SMETS 2 meter via your utility company, or via the apps Hugo or Loop Energy may be a solution. Otherwise its careful reading of historical bills. If you can only gather an annual figure, then I would assume Winter (December) consumption to be about 60% higher than Summer (June) consumption.
Step 2 is looking at where the solar panels could be sited, and estimating:
a) how many (remembering that generall panels cannot go closer than 300 mm to a roof edge to minimise damage risk from wind, and the roof wants to be as free as possible from shadows for the majority of the day, ideally for the whole year ),
b) what orientation from North (Google maps is good enough for this), and
c) what pitch, or angle from the horizontal.
This data can then be used on sites such as:
https://globalsolaratlas.info/map?c=52. ... l,160,45,5
to calculate the likely output by month of year and for the total year.
As a rule of thumb 1kWp gives about 1000 kWh/year.
Step 3 is comparing the annual and month by month figures for generation and consumption, and considering what system will give you the best advantage. A good starting point is a system that generates in a year what you use in a year, but of course you will not use all the energy you generate because you generate more in Summmer, when your use is lower, and less in Winter. The problem with going for a system much larger than this is that generally the capital or purchase cost rises faster than the savings, so the return on investment (ROI) falls, although the absolute savings may rise. A more detailed look would look month by month, and ways of maximising self-consumption (using power you generate) which will come in the next post.
