Just moved to fibre broadband but now no data showing on the Foxess 2 App. No wi-fi connection now with the inverter I guess?
Strange thing is that I thought we had a Cat 6 cable connection from the garage where the inverter lives, to the old Sky wi-fi hub as we did not have a good wi-fi out there. When we traced to cable from inverter to the Distributor board in the bungalow I find that the cable goes to a thing called a CT - Current Transfomer and did not ever go to the old wi fi hub (now removed). Baffled I am!
I just want my data back please! Any ideas please?
Cheers, Nik
No FoxCloud 2 data showing after fibre broadband fit
Assuming their is good wifi for the inverter's wifi chip then you can reprogram the wifi module to your new router following my video here:
2 x KH Series Inverters
Thanks for your help.
I assume I'm doing this on my mobile phone whilst near to the Inverter...
Nik
Nik
Correct, you need to connect to the inverters datalogger so will need to be close
