Fox ESS - Error Code-14 - Communication Fault between battery and device
Posted: Sun Nov 24, 2024 5:25 pm
by Will
Issue:
This normally means your battery bms isn't communicating with your inverter correctly.
Solution:
Check the BMS CAN cable is connected to the battery bms/master and inverter port correctly. Some inverters have two similar looking ports, ensure you're using the correct port.
Make sure the battery is turned on and powered up
Re: Fox ESS - Error Code-14 - Communication Fault between battery and device
Posted: Sat Nov 29, 2025 3:35 pm
by alano
Cable is connected and was working but now battery is completely discharged and not charging at all even though the panels are fine. The app say there is a fault on the Inverter CODE 14 but there is no explanation as to how to fix it?
