Battery discharged itself to 3% - help/advice
Posted: Mon Nov 11, 2024 3:50 pm
I noticed whilst checking through my history that my battery discharged itself to 3% just as it was supposed to stop discharging. I thought it may have been a bug in my recording, as I've jut moved away from the modbus HACS integration to my own modbus Node-Red data retrieval, but it is also recorded in the Fox Cloud data (just missed the 3% dip due to the 5minute resolution).
My On-Grid reserve was set at 16% with off grid reserve at 10%. No force charge/discharge profiles etc. I understand this is a perfectly safe/normal setting to have?
It seems that just as the battery was reaching 16% and should have stopped discharging, the discharge rate went from -1.8kW to -3.7kW and dropped from 16% to 13%, then 3% within a few minutes before starting the recovery charge at 900w.
I emailed Fox support, but haven't had anything back, so I was wondering if anyone can advise me on what to do/check.
From what I've read, this is very bad (potentially fatal) for the health of my battery!
In case it is relevant, I recently had the inverter upgraded to:
Master: 1.39
Slave: 1.01
Arm: 1.35
I have a KH10 inverter, 15kW PV total across 4 strings and 1x master, 2x slave ECS2900 batteries.
Master: 1.39
Slave: 1.01
Arm: 1.35
