Trying to understand some of the charging related sensors? (H1-G2, EP11)
Posted: Mon Nov 04, 2024 8:09 pm
						I've recently had an H-6.0-E-G2 installed and two EP11 batteries. I'm trying to understand what some of the charging related sensors in HASS are actually referring to.
I'm on intelligent octopus go, so I'm charging between 23:30 and 05:30.
Last night my batteries were charging at ~3kW (I figure setting it as slow as possible is better for them and (0.9*10.36*2)/6 = 3.1kW so I'll be setting this to 3.5kW going forward) but the "Inverter Battery Current" sensor was showing "-7.2A" while the "BMS Charge Rate" sensor was showing "29A". Which of these is actually related to the figures on the EP11 datasheet? I can see on there they're showing a max discharge/charge rate of 27A and a recommended rate of 13.5A
Just trying to work out if I'm confusing myself here...
