T15 in parallel
Negyvas99
I have t15 with 10kw grid tie inverter. Would like to install one more inverter and connect in parallel. Does t15 support parallel mode?
The later T series inverters have a 3rd RS485 port for connecting themselves in parallel - you will need to email your local Fox service with your inverter serial number and get them to confirm you have a T series that will support this function.
Negyvas99
My inverter has one rs485 port which i connected to ct meter
If you only have the one RS485 then it doesn't support parallel running - you may still be able to wire up the system in such a way that you have 2 inverters on separate circuits but it is not ideal - it still would be worth checking your inverter serial number with you local Fox service so you know for sure.
