I'm using the online PC Fox Icloud and wondered if there was somewhere i could find more details on the various screens andon the data graphs and data descriptions etc
eg difference between output power , discharge power, FEED-In power but there are others.
Is there a Glossary that can be refered too.
thanks
There are no obvious glossaries, but this post from some time ago might help a bit viewtopic.php?p=2971&hilit=yield#p2971
And there is this for the V2 app https://github.com/TonyM1958/FoxESS-Clo ... Fox-App-v2
If you haven't already got it, I would suggest getting the Energy Stats app which is written by a community member (Al Priest) and it is widely accepted as the easiest to use and understand.
If you have an iOS device you can get it here https://apps.apple.com/gb/app/energy-stats/id1644492526 or if you have an Android device it is here https://play.google.com/store/apps/deta ... nergystats
Gents,
following on from the previous post .
i currently have "Feed-In" out to the grid from grid tied Solar when my battery is showing SOC 18%. There is no other loading on the house so i would have thought the solar would have started to charge the battery rather than export to grid (FEED-In).
I currently have enable charge from grid to from 1am to 3 am and No grid charge from 11.00 to 23.00.
i would have thought that the "FEED-in" to grid would only occur when the Battery was at 100% and no capacity for spare grid tied Solar to charge. There was a period from 09.00 to 11.00 that the solar did start to charge the battery during this period but started from 12 ongoing.
![Image]()
appreciate any assistance on this
If the inverter is in Feed-in work mode, any solar will cover house load first and the remainder will export to the grid.martint007 wrote: ↑Thu Feb 06, 2025 1:56 pm Gents,
If you want to charge the battery before exporting to the grid, select Self-Use workmode.
If you are in Self-Use work mode and have set a charge period with ‘no grid charge’ enabled, the battery will not allow itself to discharge but it will charge from solar.
